KB3ZIM
Hello Everyone!
I have a BCD526HP that I haven't used in quite a long while, maybe two years or more. I got it out yesterday with the intent of setting it up for continuous regular use in my ham shack. When I powered it up, it began to display opening screen info, followed by the "normal" screen info, and then moments later, shut down...only to begin constantly repeating that process over and over and.....
I attempted several things like removing the SD card and powering-up, using the "1>9>e hold and power-up reset," etc. Didn't help. USB cable to computer didn't help, and in fact, wasn't being recognized by the computer during initial attempts. I downloaded Sentinel software directly from Uniden, reformatted the card and wrote from Sentinel to the card, and then put the card in the scanner...powered up...still no dice. The files on the card appear to be okay.
There were times...like now...when the radio did recognize the computer connection and displays "USB Mass Storage," signifying that it is now being recognized by the computer. The card in the rig now also displays in the "This Computer" folder on my computer. I am leaving it that way for now, as it's the only way I can get the rig to stop the constant power cycling.
I've read that the radio has to be powered on for a long time (50+ hours??) to recharge the clock battery. Perhaps that is necessary to be charged to keep the rig's memory intact and prevent constant power cycling?
Anyway...there you go. I may not have explained it accurately, but I'll do more research before I jump to the conclusion that it's in need of repair and send it out. I posted this because I'm wondering if anyone else has encountered this same problem with their BCD536HP.
Thanks for any assistance you might be able to render. Best wishes...stay safe and healthy!
73 de KB3ZIM
Coatesville, PA USA
73 de KB3ZIM
Coatesville, PA USA
