BCD536HP: uniden bcd536hp wifi dongle
qc
San Francisco Bay Area
Hi, just wanted to confirm the Uniden bcd536hp wifi dongle is only to controls the scanner via app and you can’t do any Database or Firmware updates?
fxdscon
°¯\_(ツ)_/¯°
That's correct....
The scanner must be connected to your PC with the included USB cable for firmware and database updates through the Sentinel software running on your PC.
Or, you can put the SD card in a card reader connected to your PC and perform those updates through Sentinel, and put the card back in the scanner.
rcool101
BUCKEYE NATION
I use my dongle everyday with ProScan. (except for database and firmware) You don't need a USB cable. You can listen to your 536 thru the PC speakers and run a feed with TG ids wireless also. Still waiting on the Siren app though. There's a 30 day demo if you never used it.
davidgeo
Corpus Christi, TX
BCD536HP and ProScan
I've been trying for weeks to get ProScan Pro to connect to the 536 dongle remotely without success. What's the secret? All help will be greatly appreciated.
D
darunimal
Guest
Is the 536 connected to a local router and does the router allow you to open ports, what's the dongles firmware, details, details, details!!!!
davidgeo
Corpus Christi, TX
Scanner is connected to local router via the 536 dongle and WiFi
Dongle firmware v. 7.28
What ports should be opened on router.
davidgeo
Corpus Christi, TX
Thanks for your hijacking concerns. Should have told me that in the first place instead of asking questions about - details, details, details!!!!
D
darunimal
Guest
Well, now, I know its not a Dongle issue since the firmware version is correct!
ProScan
Software Provider
Ontario, Calif.
Are you using this format exactly --> rtsp://192.168.1.109/au:scanner.au
Subsitute IP address with yours.
Voyager
To repeat the question... are you using ACCESS POINT mode or Infrastructure mode? What is the scanner's IP?
