Calfire406
- Joined
- Nov 24, 2020
- Messages
- 5
Livingston County NYWhat is your city, county, and state and which system are you trying to monitor?
Most of the Channels are P25 Phase 2
Which ones do. I’m open to most ideas or modelsThe Livingston County system is simulcast, which means you may have limited or no luck monitoring it with a BCD996P2. While that model scanner is "Phase 2" compatible, it does not handle simulcast well.
Am I correct that this is the system?Livingston County NY
The best bets dealing with Simulcast are Uniden's SDS series scanners (the SDS200 is the base/mobile version), one of the Unication pagers, or this receiver:Which ones do. I’m open to most ideas or models
I understand that but what do you do copy and paste in the radio reference database into pro scan,i will give you a hint, its called import, easy piezy.
You can use the Get Clipboard function for that. It works at the channel level so the system needs to be setup first.I understand that but what do you do copy and paste in the radio reference database into pro scan,
Thank You,You can use the Get Clipboard function for that. It works at the channel level so the system needs to be setup first.
It's easier to import the system by going to the menu Database - Import - RadioReference Web. A database file needs to be opened or created first. Do that by going to the menu Database - New (or Open).
Are you sure, that you understand Bob's(Proscan) most recent response? Looking at your portion, of the Proscan thread, I am not sure you do. Last night, I deleted a very lengthy response of mine. Before I sent it. Because I didn't want to step on Bob's toes'.Thank You,
One last Question and i have all weekend to play, Can i set everything up, Your systems and channels without my 996 scanner pluged into my laptop computer. Then when i am good to go, at that point upload it to my scanner like i did in Freescan?
I guess what im asking can it be saved in Proscan and then when I am ready plud in scanner and up load.
Merry Christmas
Bob one more question, I'm making head way lol, on the import page under login the unchecked box, Channels, use the description name instead of the display name?? has me confused.You can use the Get Clipboard function for that. It works at the channel level so the system needs to be setup first.
Take a look at the RRDB. You should see a Alpha Tag column and Description column at the channel level.Bob one more question, I'm making head way lol, on the import page under login the unchecked box, Channels, use the description name instead of the display name?? has me confused.
Is the sound steady, like this'------------' or, is it intermittent but steady, like this '- - - - - - - -'?ok figured it out, Thanks for the Help !!!
one last question my BCD325p2 when plugged into my Laptop has no sound but if I connect my 996P2 I get sound on the computer? is it a setting or is there a different cable ?
Everything in Proscan is working except the sound.
Not sure you understand me, there is no sound coming out of the lap top speakers when scanning with pro scan opened up and running. Not trying to broadcast over IP just my laptop.Is the sound steady, like this'------------' or, is it intermittent but steady, like this '- - - - - - - -'?
Think of the 'steady' being fine electrical power. But the 'intermittent' is like an electrical short.
What I meant was. When the 996p2 is connected, you said you get sound out of your laptop's speakers. You didn't say, if it is steady, or intermittent sound. So, Depending on sound coming through your laptop's speakers. It could either be something as simple as changing the 'Scanner Type', in ProScan. But it could be a bad cable.Not sure you understand me, there is no sound coming out of the lap top speakers when scanning with pro scan opened up and running. Not trying to broadcast over IP just my laptop.
Ensure you are using a stereo cable.ok figured it out, Thanks for the Help !!!
