chazcarly
Ok Getting close, Did what you said, Getting sound but it has a BAD echo .....Ensure you are using a stereo cable.
Go to the Audio Control - Recorder tab then set the input Sound Device to the input using. Do you see audio moving in the meters?
If you do then go to the Audio Control - Monitor & Test tab then select the Recorder Audio Service then click the Loopback box.
