Hello guys, I'm recently getting into scanning trunked radio systems and have a question because perhaps I programmed my scanner inefficiently. Here in NC we use a statewide system called VIPER. I have read tons on the forums and have figured out how to use FreeSCAN and add systems, sites, and talkgroups. This will be a mobile unit and I travel across different counties pretty regularly. I decided to take the advise of one member and add all the counties that I will travel thru and name each system the name of the county, I then added all the sites in that county to the corressponding system. The RR import feature in FreeSCAN saved a lot of time. I assigned QKs for each system so that I can just leave the one county I happen to be in enabled and the rest turned off. For a simple test I added the NCSHP and DOT talkgroup for each system and assigned NCSHP talkgroup QK "1" and DOT "2" so I could listen to both or just one if I prefer. I also have it set to ID SCAN, I thought I did this correctly but when I uploaded it to the scanner I assumed it would just scan the talkgroups on each site but it wants the scan all the frequency's associated with each site and then the 2 talkgroups in every site so it takes a few seconds to go through all the frequency's which are irrelevant because the talkgroups are the only thing that has transmissions. Did I do something wrong? is it a setting in the scanner I need to change? I appreciate any input and hope to learn more about all of this!
