I appriciate the file. I must be doing something wrong. Downloaded and unzipped the file. Uploaded it to the scanner with freescan and have the screen saying nothing to scan.
Sounds like, somehow, it got locked out. It's not locked in the copy on my pc (that I 'zipped').
Open the file in FreeScan.
With that file open, select the Tools menu at the top
From the drop-down menu, select "Quick key manager". (shortcut to that is <CTRL>+<K>)
That will show you all the quick keys. You should see # 25 slightly boldfaced, and it should have a checkmark in the box by it. If it does not, put one there. Or, just use the "all on" button", then hit "OK".
I assigned all the sites in the file to 25 (just picked a number).
Now, back at the main screen, select Tools again, and from the drop down menu, select "unlock system/sites"
Now, reload that file. Use the option to either erase the scanner first, or the middle option, "replace all systems with same name......"
I just loaded that file in one of my scanners, and it came up running (though obviously, I'm out of range!).
The "nothing to scan" error means either no systems are loaded, or all systems loaded are locked out.
