Uniden bearcat 980 insane swr.
slowmover
Fort Worth
This guy in video below reacted fairly well. But the maroon behind him was too close and started to lose it so cameraman went to right.
Idiots in left lane are all on suicide mission. That right lane wreck should it have happened immediately in front of big truck means truck has right of way to move to passing lane instantly. “Presence” is not right-of-way. Your vehicle in left lane jam is going to get body-slammed down across median, sayonara.
There’s no such thing as Fast Lane and Slow Lane.
It’s illegal to bunch up and to block passing lane entry.
A pass means one must execute it in the shortest time/space possible. If that means “speeding”, in your car then why are you passing?
Vehicle in travel lane also obligated to get vehicle passing around quickest (back out of it enough)
Cooperation is both the spirit and the letter of the law
CB always “on” is best. I run cophase to have best ears of which tallest antennas is part. I don’t want trailer blocking signal capture (it does). Most big trucks have poor radio rigs.
This driver had a “decent” following distance. All the cars in the left lane need some jail time.
OP, don’t stop just because you get a decent SWR. Get best ears, etc. Get a plan and make further improvements. Worth every bit.
Overcoming the deficiencies of other radio rigs is the game. Distant Early Warning.
“Brake Check” is insufficient.
“Emergency Stop, Brake Check” (repeat)
“Interstate 40, MILE MARKER 368
Westbound!!”
Keep repeating.
Other drivers are likely to only hear direction of travel. So, repeat.
slowmover
Fort Worth
A U980 all dressed up and ready to go to town with an RM ITALY KL-203 tuxedo
With cophase it’s about 35/40W average per antenna given you aren’t straining factory wiring (best to run your own ASAP). I’ve used this in many trucks.
Big trucks need radio crutches. Amp is left leg.
Gets you a few more miles to have questions answered. Gets your emergency warning out to where it can be heard.
DSP in the audio is the real game-changer. The right leg crutch. I’ve posted elsewhere at length. (Also makes listening to a “digital” radio easier on the ears).
Hear, . . and Get Heard.
tvengr
Well Known Member
Baltimore County, MD
Tune the antennas with the doors closed which is how they will be when making your runs. SWR will most likely be different with the doors open.
Dekgit
Lots of info.
I'll get things on order and next time I can swing by home I'll get them.
Also, I have this stud, a roadpro, would this be better than larger one I have currently installed?
Dekgit
Ironically, I'm in fort worth TX unloading at receiver now. Haha
slowmover
Fort Worth
Larry’s CB
McKinney, TX
I love this place. Santa’s Workshop.
He doesn’t stay open late. Had the -p version 203 around last year. Also had some Skipshooters in the rafters.
It’s a little funny getting in there. Have to get off US-380 at grocery store just before his street and come in from back way in order to park across from. (Study sat pics; he’s at an old house). You’d be parked facing US-380 is the point to leave and turn left or right.
— The Petro a very short distance west at Weatherford, TX has a small shop, well-run.
— There’s another shop that’s okay a couple miles short across from the Pilot. Uses an MFJ-259 analyzer, just doesn’t know much about its capabilities.
Can’t say what they have for antennas. Larry’s usually has something long.
slowmover
Fort Worth
Which direction you headed out? (And did you see post before last one?). I have one I can give you. PM sent.
prcguy
Those studs are not that great either, when you tighten them it starts crushing the internal white insulation between the brass and chrome parts. They are ok for short 4ft or less antennas but larger antennas will work the mount loose. I like a mount that I install once and it lasts a really long time with whatever I stick on it from small whips to 9ft stainless steel, Hamsticks, etc. The Sirio mount will do that and most will need constant tightening then the insulator will squish and fail.
Lots of info.
west-pac
Are you using the SWR meter on the radio to measure your SWR?
Is your Astatic PDC-1 still in-line?
Dekgit
I'm working with what i got for moment. Been on road for month now again.
Dekgit
I had it inine but I don't think it's working as intended. I don't have a patch cable, only a 9ft coax spare. Radio was claiming 7+ swr with meter inline.
Dekgit
I'm gonna be heading back northeast. I'm just 3 months into this career, still a rookie. Is easier the little experience I have to get a CB going on a car than this darn truck haha.
west-pac
Yes, if you were trying to use an SWR meter in the radio, while having another SWR meter in-line it will show an incorrect SWR. The radio would think the in-line SWR meter is part of the antenna.
Dekgit
Gotcha. But does calibrating the meter change my swr? I don't understand how it works exactly.
slowmover
Fort Worth
Composite-body fleet trucks are a PITA the first time through.
I’ll let you fill things in, but my old 7’ Skipshooter plow horse now has a new home.
It was a pleasure to have met a man new to the business with right attitude and as willing to bite off a big chunk of responsibility as he has done. My hat is off to him as I understand what that entails.
slowmover
Fort Worth
going anywhere near So Cal in the future? If so I could check out your setup and dial it in.
I sincerely hope the OP will grab a load going out that way.
I found him to be more than just an apt student for my abilities. Skip him forward a couple of grade levels would be good for us all.
Speaking as a truck driver I know what it means to have a good man with a very good radio rig out on the big road.
There’ll be those who’ve no clue their journey on this earth didn’t end prematurely his type exists. Those reading this may understand when suddenly they’re passing several big trucks at a much higher rate of speed than just a moment ago.
