My rig:
Radio:
Uniden BEARCAT 980 40- Channel SSB CB Radio with Sideband NOAA WeatherBand
Power supply:
Pyramid PS9KX Universal Compact Bench Power Supply-5 Amp Linear Regulated Home Lab Benchtop Converter w/ 13.8 Volt DC 115V AC 70 Watt Input, Screw Type Terminal
Antenna:
Nagoya CB-72 28" CB Antenna (26-28 MHz), Center Coil-Loaded Heavy Duty Spring with Magnetic Mount, Includes 18' of RG-58A/U Cable with a PL-259 Connector
I am using this radio as a base station.
The problem… I’m getting a strong signal as soon as I turn on the radio. Even with the squelch turned all the way up, I still hear a clicking noise. This signal is constant, on all channels 1-40, including upper and lower sideband. The only thing that comes in clear is the NOAA weather station, but I know that’s in a different frequency range.
Also, according to the built in swr meter (I’ve read its unreliable) my swr’s are running from 6 to 8+. I’m out of ideas guys and I don’t know what to try next. Thank you for any help.
Radio:
Power supply:
Antenna:
