Hello, I am new this forum and have looked for some information on this forum but failed to find the information I wanted. I am hopeful that someone who frequents this forum board can answer my question.
I have a Uniden Bearcat BC 560XLT scanner. I had a resister burn up and the scanner lost it's ability to receive any of the frequency bands it is designed to receive.
I do not know what value the resister was, so I replaced it with a common resister value of 100 Ohms. The bands still fail to receive any of the bands. I have used a signal generator and it appears that one of the IF stages is still operative, however I am sure the mixers are out of commission.
I have a schematic diagram of the scanner, the problem I am faced with is that Uniden did not mark the printed circuit board for the resistor part numbers. There is simply a marking for the resistors but no part numbers such as R1 or R15. I have tried unsuccessfully to find a printed circuit board map, so I can at least identify which resistor it is. I do know the resistor is in the power circuitry which includes the on-off switch and IC6 which is the IR3M03A chip.
The resistor is located right next to the D5 which is a diode.
What value in Ohms is this resister? If anything at least post the color bands.
Thanks in advance.
Bruce.
Thanks in advance.
Bruce.
