scottyhetzel
I can't believe no one at uniden has released the P2 manual? Hopefully a owner can post a link...
Uniden will likely have the driver on the website shortly.
As for the manual, use the 996XT manual for now.
So I received 2 bricks in the mail today called 996p2's. The programming cord sent with them won't work, my computer says the driver needs to be updated for the cord. Anyone?
My new BCD996P2 is en route. Arrival date is Wednesday. I am bummed though after reading that my RH-96 is not compatible due to the change in front port (proprietary to mini-USB). Several sites advertised it as RH-96 compatible. Now I can't use it in the Prius. I have my current BCD996XT installed under the seat with the RH-96 attached to it's mounting bracket as a base on a tether cable resting in the lower console along with a small speaker. I can pick up the RH-96 at will and manipulate it, place it back in the lower console when not using. I installed a master power switch in one of the unused dash plugs that powers both on and off. I have an NMO mount drilled center roof. After experimenting with several NMO mount antennas, I am using an uncut Stico flexible whip NMO that is about 19" long. It all works well. Now my new P2 will just have to be a base station in the house until UpMan comes up with an adapter for my RH-96....
_____________________________________________________________________________________
Uniden BCD396XT, BCD996XT, RH-96 / Yaesu FT-60, FT-90, FT-8800, FTM-10R
Curious as what sites advertize it compatible with the RH-96?
