K0BLR
Hi there everyone!
How are we doing? Ben, K0BLR here. I just bought a uniden beartrunk tracker V for my truck to go along with the IC-7100 that I just bought, and I wanted to ask everyone here……Does anyone know away how I can route the gps antenna, and the rx antenna for the scanner? The scanner came with one of those telescoping antennas, but that may or may not hear the best. So I was going to swap the wire antenna from the 885 and use that for the scanner, and put the telescoping antenna on the 885. I should mention here the 885 will be used as a base radio. Do I need an external antenna for the scanner or will the wire work? The scanner was going to go in the cubby where the CB would normally be.
thoughts anyone
ben, k0BLR
thoughts anyone
ben, k0BLR
