- Joined
- Feb 20, 2003
- Messages
- 1,242
- Reaction score
- 94
Does the TRX-1 have a feature like the Uniden Discover feature?
Each tg has its open record option in settings when programmingI was monitoring a DMR system one time and the scanner recorded the talkgroups with recording, but I don't remember how I did it.
Okay. So if I have the wildcard tag on for recording this will log all the tags.Each tg has its open record option in settings when programming
Generally speaking, a wildcard set to record will provide you with all the TG's it finds, as well as time/date stamping, control channel use, and other good metadata.Okay. So if I have the wildcard tag on for recording this will log all the tags.
Thanks, I couldn’t remember what I did.Generally speaking, a wildcard set to record will provide you with all the TG's it finds, as well as time/date stamping, control channel use, and other good metadata.
73/Allen (N4JRI)
You could do it that way also, but then you won't know who is talking unless you memorize talkgroup numbers to aliases via RR, or figure them out as they talk..Okay. So if I have the wildcard tag on for recording this will log all the tags.
As Reconrider suggests, I would consider it as standard practice to enable Global Enable and Search Enable in EZScan (Advanced Options > Audio Option> Recording Options).Thanks, I couldn’t remember what I did.
That's the best way to do it, have it do discover while you are using the scanner like normal. I always have a wildcard in all systems to record everything unknown and all TG's and CTCSS's that are known and programmed do not have recording set to them. Then I copy recordings once a week to the PC and analyze using USAP. You can't do that with a Uniden scanner as it lacks specific wildcard settings.Generally speaking, a wildcard set to record will provide you with all the TG's it finds...
/Ubbe
Where are the recording files located on the chip? So, when you have the wildcard set to record and there are known talkgroups not set to record, then the known talkgroups are not recorded. I think I got it right.
On the SD card, your audio files are in a folder labeled as Rec.Where are the recordings located on the SD card?
For the Uniden scanners, I use the Universal Scanner Audio Player. I have used it on my TRX-1 at times, though for that specfiic scanner, I normally just use EZ-Scan.
