I have a few minor issues with Uniden Firmware upgrader version 3 that is used to upgrade the XT line, and will be the required firmware upgrade utility for all scanners going forward (from what I have been reading)..
My major complaint about this software is the requirement that it must pull the firmware off the internet every time you want to do an upgrade. This is an issue for me because I upgrade radios "in the field" and do not have access to WiFi or "LAN" while roaming around. The old version 2 of BC_VUP allowed me to save the firmware locally on my computer before running the updates. Now with version 3, I need to turn on the WiFi hotspot on my cell phone before running these updates. It is an extra step, and not always something that I can do while roaming around. There has also been a single occasion where the Uniden website has been down and I have been unable to pull the updates required. Murphy was sitting next to me that day because it was the only time I noticed that the firmware could not be pulled. It would be nice to have an option in the software where you could chose "local copy" or "upgrade/download from internet" so that if there is no access to the 'net the firmware upgrades can still be done.
My second problem is that I have been unsuccessful at doing any radio upgrades via my Windows 7 64bit desktop. I don't have any problems communicating to the radios with BuTel or ProScan, so it isn't a communications issue over the serial lines. I have "hard" serial ports on my pc because I play a lot of radio. My XT radios will enter firmware upgrade mode, the radio's display will blank out with the backlight on, but the firmware upgrade process will fail part of the way through. I have admin rights on my computer, run the application as administrator, and have even set it to run as Windows XP. No Luck. I have had issues with my BCT15x, BCD996XT, BC346XT, and a BCD396XT. I have not tried anything that upgrades from BC-VUP v2 yet because all of those scanners are up to date on firmware. I could try and upload to the same FW version in one of my other radios if it would help with troubleshooting (I have lots of toys). The solution I have to upgrade any radio using v3 so far has been to do all my Firmware upgrades on my Windows XP netbook. This works well when I am at home, and it is the same computer I use when I complain about my first item on the list
Thanks & 73
Phil / w2lie
Thanks & 73
Phil / w2lie
