I am new to this forum so I hope I ask this question correctly and use the correct terminology. I live in Broward County FL and the public safety department recently upgraded to Project 25 Phase II. I just purchased the HP-2 scanner. The scanner is not receiving this channel. However, it appears this scanner does not recognize HEX: 997 BEE00 but only the Simulcast frequency. Unless I lock in the TGID specific 12010, which I assume is finding 774.90625c, I sporadically get chatter. I see four bars next to the battery that indicates the signal is strong. When I scan two channels, no chatter is heard. I have turned down the squelch to 2 and distance to 15 and confirmed the correct services are selected. Should I return this unit and buy a different scanner that would recognize the Project 25 Phase II TDMA modulation or could the signal or the talk group BCP D3 be secured that no scanner would pick up this frequency? I appreciate any information anyone has on this issue. Thank you.
Your biggest problem is that the Primary site (listed as Primary Simulcast) is just that, Simulcast.
This what you get on the database when you click on that small icon near the lower left corner of the map:
That only shows two sites. But focusing only on the primaty control channel frequency, 774.90625, I see that the frequency is also on two other FCC frequencies, each with multiple sites:
FCC Callsign WRDZ767 (BROWARD COUNTY BOARD OF COUNTY COMMISSIONERS)
www.radioreference.com
FCC Callsign WQYB999 (BROWARD COUNTY BOARD OF COUNTY COMMISSIONERS)
Each of those have multiple transmit site locations.
So, instead of a two-site simulcast, as the database implies right now, it appears that you may be dealing with a simulcast site with a dozen or so transmit towers. The HP-2 is a decent, easy to use, scanner. I have one myself. But Simulcast is it's nemesis.
From a fixed location, you may be able to use a directional antenna to focus reception on a single tower. Or, use "less" antenna, even to the point of using a paper clip. Might work, might not, but a paper clip is a a very low cost option to at least try.
Read more about the effects of simulcast in the Wiki:
wiki.radioreference.com
The only true scanners designed to deal with Simulcast are the Uniden SDS100 and SDS200.
The Unication pagers also work well against simulcast, but you are limited to one site, and up to 64 talkgroups, that can be scanned at any one time. You can program addition sites (like for other systems), and other sets of talkgroups, but only one site and no more than 64 TGIDs can be monitored at a time.
The
BlueTail receiver also can deal with simulcast. I don't have this unit, and do not have one of the Unication pagers, but multiple comments in the forums indicate that these do work well.
Your other, lowest cost, option, if you are scanning from home & can utilize your PC, is to use one or more of the SDR dongles, along with downloadable (free) software to monitor the system. Again, this is not something I'm using, but a number of members are, apparent;y with success.
