RClary11
I am thinking of getting this scanner. I wonder if anyone here has this model of scanner? And can you use the zip scanner feature in Canada?
I am in Sault Ste. Marie Ontario and I have a home patrol 2 and a BCD436hp. I typically listen to fleetnet and I can confirm the enter your zip works in Canada (postal code) I would recommend you look into antennas for it.
Cheers
Hopefully others can help as I don’t recall what kind of antenna I have is, I got an antenna from amazon and it was a shot in the dark for sure...
Does it automatically find the fleetnet talk groups when you enter the postal code?
There is a little more to it, of course. It will scan through all Conventional, then Trunked systems that are preloaded into it.
The default Service Types when you first purchase a HomePatrol 2 are Law Dispatch, Fire Dispatch, EMS Dispatch.
If you look at the FleetNet system in the database. There are many more service types, so you will have to select them to ensure nothing is missed. Also, you may want to modify the range to extend the listening area.
You can use the Full Database, but what I have done is to append the Full DB to a Favourite List. You can modify a Favourite List, not the Full Database.
Using the built-in database everything you need should already be included. You can append systems from the database to create your Favorite Lists.What I wonder is, when it comes to OPP programming, do I have to program in the base spacing and offset numbers?
The scanner should have come with a sma-BNC adapter. You can use any USB wall wart to power the scanner.
I guess i could use the charger that came with my android phone. Would that work?
Not true. You can save thousands of frequencies if you so choose. You're doing somethiong wrong.
