Uniden Home Patrol HP-1, Garmin Nuvi 350, And Radio Shack Amplified Speaker
JASII
Memory Capacity
I decided to go with the Uniden Home Patrol HP-1 with a Ram Mount, connected to a Garmin Nuvi 350 for both navigation and the Uniden, driving a Radio Shack Amplified Communications speaker also mounted to the windshield with a Ram mount. I used 1/2 flexible split tubing (loom) to keep the three power wires together and connect to a Wagan Twin USB/DC Power Adapter. So far, I really am liking this set up. I really like having one GPS for BOTH the Uniden and navigation. The Ram Mounts seem to really work well. I am tempted to switch from a Garmin mount to a Ram mount for the Garmin Nuvi 350.
Now I just need to figure out which antenna and mobile mount to use. Right now I am just using an 800 mHz commercial rubber duck antenna inside the vehicle. For listening to the Minnesota ARMER system it is fine, but for other stuff I may want a mobile antenna.
russellmaher
KC1ANC
Enfield, CT
Hi JASII:
That's a very impressive setup! Looks neat and clean and should work very nice for you now and even better after you mount an external antenna. I use a Spectra trunk mount on my mobile and love how it receives, but everyone has their own favorites so you'll get a lot of opinions.
Now tell me - don't you get nervous leaving this setup in the vehicle in plain sight when you're not in it or within visual range?? If you're in a low crime area that's fine, but I'd be sleeping in the car overnight.
Anyway...well done on the installation!
Here's the Spectra on my mobile...just to show you.
Russell
JASII
Memory Capacity
Thank you for the reply. No, I am not nervous because I aprk it in the attached garage at home. I live on a five acre hobby farm in the country. At work I park in an underground parking garage of a building that is, well, lets just say very secure.
Now, if I lived here Google Maps Catches Teens With Gun At House Where Baby Found Dead « CBS Detroit in Detroit next to those fellas, I might be a bit more concerned. On the other hand, perhaps they getting ready to go pheasant hunting. You just never know, there might be quite a few pheasants in Detroit!
JASII
Memory Capacity
Here is what it looks like at night.
phask
zanesville
Seems like the passenger side airbag could turn the speaker into a projectile (I may be wrong due to angles).
RLozano02
Just a quick question......I was under the impression that the Garmin Nuvi's would not work with the HP-1. Have I been mislead, and how old is that Garmin unit, and how did you hook it up, if I may ask ??? Thanks !!!!
JASII
Memory Capacity
GTRANS Garmin to NMEA Translator Cable (D-Sub Style)
GTRANS Garmin to NMEA Translator Cable (D-Sub Style) - Argent Data Systems - APRS Hardware
You need the Argent Data Systems GTRANS Garmin to NMEA Translator Cable (D-Sub Style). That allows the Garmin Fleet Management Interface data to get converted to NMEA-0183, which is what the Uniden Home Patrol HP-1 uses. The Garmin Nuvi 350 is about 6 years old. The Garmin units known to be compatible with this are:
Garmin nüvi 300 series
StreetPilot c340
StreetPilot 7000 series
StreetPilot 2820 series
StreetPilot 2720 series
zumo 400 series
zumo 500 series
JASII
Memory Capacity
Mastiff2013
