Where do I select ID-Search:On? Is there one place on line or otherwise I can go to see how this should all look? Perhaps I could sort this out yself then.
I found this setting and created a favorite list with just the one frequency and only Troop G but I'm still not hearing anything. I will check through everything again. I must be missing something.
You can always post the favorite list you created.
Edit your Profile to verify settings.
Under Favorites List Tab, be sure the Monitor option is on and location control is Off. Also, as was mentioned, pay attention to what Service Type is in the list of talkgroups. If it is Custom 1, be sure that is enabled in the Service Types tab or better yet, make it Law Dispatch and verify it is enabled.
