Uniden Introduces 3 new CB Radios -- Radical new designs
UPMan
In Memoriam
Arlington, TX
The PRO505XL introduces a low-cost CB incorporating a PA function.
The PRO505XL is small, easy to install, and has a big LCD with great viewability.
The Bearcat 680 introduces a radical new design to the core CB lineup. Incorporating all the great features familiar to users of the PC68XL, it includes a large display that clearly shows the operating channel, S/RF levels, and the status of all options.
The Bearcat 680 incorporates PA, Mic Gain, LO/DX RF Level, Automatic Noise Limiter and Noise Blanker, and rapid channel 9/19 hot key. It will also be compatible with a Wireless Microphone (available Summer 2012).
The biggest change to CBs since 1985, the Bearcat 880 takes a radical new approach to a mature product category.
The Bearcat 880 incorporates a 7-color backlit display, integrated SWR meter, frequency display, talkback, adjustable Mic Gain and RF Gain, Automatic Noise Limiter, Noise Blanker, PA function, Weather with Alert, Day/Night backlight settings so you can instantly switch to your desired backlight color and brightness, radio diagnostics, memory channels with memory channel scan, and compatibility with a wireless microphone (expected to be available Summer 2012). It includes a noise-canceling microphone.
PRO505XL and Bearcat 680 are shipping now. Bearcat 880 will begin shipping in the next few months.
UPMan
In Memoriam
Arlington, TX
That wireless mic photo is a preliminary design concept, and not really even close to what the final design will look like (other than generally being a microphone-shaped thing). The color display image also does not accurately reflect the colors on the display. I think these came from a presentation we were showing to some customers (who would have been told that images are not all final, yet).
No Bluetooth.
More models to come! (I'll let you know about them after FCC is granted.)
bryan_herbert
Las Vegas, NV. DM26jc
I really like the look of the radio and mic in the third photo. But the radio needs to have sideband before ill consider buying a CB.
reedeb
Dallas Texas
No sideband, No remote head, No 5,000 watt kicker, WAAAAAA!!!
All I need is a simple rig. BUT if you INSIST on having all the goodies, they DO make radios like that by OTHR companies. I suppose the size of these rigs are a main reason they don't add all your forsaken goodies. AND for the price I don't see it happening.
EC-7
Saginaw Co. Michigan
A remote head is almost a MUST for mobile radios now, due to the dash of newer vehicles. Im disappointed that CBs haven't caught on yet.
n3obl
ØAES-1024
PA
Uniden makes a cb that looks like a 996 scanner that has a back mic jack on it. Too bad its only for aus/NZ market.
Frank
Scottsbluff, NE 69361
We need a rig that has an ultra stable pll oscillator like most ham rigs do, we need sideband, some filtering options, and a remote head. they can do similar to the ham market and make the remote head, ultra stable oscillator and extra filtering an add on/upgrade option. this will keep initial cost down and allow those who want the advanced upgrades to have them.
i think a wireless bluetooth headset with a remote ptt that can mount to steering wheel would be nice as well.
too bad the fcc now requires type acceptance for cb's, i beleive back in the 60's they didn't you could actually build them from scratch or kits just so long as the radio conformed to the technical specifications.
wish we would go back to them days. the fcc could require that you have a ham license to build you're own cb rig.
i believe (at least under part 15) you can build up to 5 rigs for testing purposes without needing certification, not sure if this applies to other services as well.
Central AL
There's actually another model called the Bearcat 980. It looks just like the 880 but it has sideband as well. I guess Uniden has decided to come out with an SSB rig again. Hopefully it will be stable.
OCO
Central Michigan
Showing my ignorance - I've seen two references that indicate drift on SSB CBs. Is that a problem now? The stuff I worked on back in the 70's was pretty solid unless the clarifier mod wasn't done right.. The specs was something like +- 1PPM and the PLLs were locked to a crystal.. Drift? I could tell ya about a Siltronix 1011B that..........
MtnBiker2005
San Diego County, California
Uniden BC980 SSB CB Radio - Price: $199.99
http://www.truckers-store.com/store...oon-Uniden-BC980-SSB-CB-Radio_1097860610.html
http://cb-world.info/Uniden/uniden_bearcat_980_frames.htm
http://www.westcoastmall.net/undien-bc980-bearcat-980-cb-radio-ssb-lsb-usb-pi-6822.html
http://www.deepsouthradios.com/forum/showthread.php?459-On-the-way-from-Uniden/page2
http://www.thetruckersreport.com/tr...dio-forum/158973-coming-soon-from-uniden.html
http://www.mauldroppers.com/showthread.php?16694-New-Uniden-SSB-Radio
______________________________
See UPMan post on the other forum topic. About the above radio photo & info.
The image posted in this forum does not reflect the final design or feature set. As this unit has not yet received an FCC Grant, it is a bit early for us to be talking about it (basically everything here is based on leaked early images and specs).
Of course, the final design includes a front-panel clarifier knob. Beyond that, keep watching for more official information.
http://www.worldwidedx.com/cb-band-...ideband-citizens-band-radio-2.html#post326786
MtnBiker2005
Bearcat 880 - FCC ID 'AMWUT390' Link.
View Attachment Exhibit Type Date Submitted to FCC Display Type Date Available
PDF LINK: Confidential Letter - Cover Letter(s) - 10/10/2011 - pdf - 10/10/2011
PDF LINK: External Photos - External Photos - 10/10/2011 - pdf - 10/10/2011
PDF LINK: Label Location - ID Label/Location Info - 10/10/2011 - pdf - 10/10/2011
PDF LINK: Internal Photos - Internal Photos - 10/10/2011 - pdf - 10/10/2011
PDF LINK: Test Report - Test Report - 10/10/2011 - pdf - 10/10/2011
PDF LINK: Test Setup Photos -Test Setup Photos - 10/10/2011 - pdf - 10/10/2011
PDF LINK: Users Manual - Users Manual - 10/10/2011 - pdf - 10/10/2011
gewecke
Banned
Illinois
Ok this might pique my interest a little. Enough to buy a cb again.....NAH!! :lol:
It is kinda cool looking tho.
73,
n9zas
brianearlspilner
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.3; en-us; DROID2 GLOBAL Build/4.5.1_57_D2G-38) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
Forget the 505. No RF gain. I'll just stick to my Uniden 520XL.
n9mxq
Belvidere IL
Who needs memory channels when there's only 40 channels?????
gewecke
Banned
Illinois
Interesting...if I could view the links? It says "not allowed to access this page"
73,
n9zas
