I was listening to my BCT15X in my truck. After running around all day I unplugged the scanner to take it in the house. I plugged it back in the the wall adapter and nothing. What happened to my scanner.
Hard to do that if his scanner won't power up.From the Easy to read site:
Easier to Read BCT15-X Scanner Manual
Scanner Reset: to initialize the scanner's memory, turn off the scanner. Then press 2, 9, and Hold while turning it on (remember the game called Twister?). The scanner will give you the option 'Restore Pre-program List? "Yes"=E / No="."', if you press 'E/Yes', the scanner reloads the pre-programmed systems.
Important! This deletes all programmed data.
Never hurts to try, if it doesn't work..... at least you tried..Hard to do that if his scanner won't power up.
