uniden power supply 396xt
garys
The power supply is primarily a charger, not primarily a power supply.
randybcd396t
Los Angeles
The supplied power supply can power the scanner. Batteries do not need to be installed in the scanner.
The power supply can also power the charging of rechargable batteries that are installed in the scanner. There is a switch under the batteries that has to be set to enable this.
