uniden question
scannersnstuff
i have a weird,but stupid uniden question. i had my bcd396t setup for a 800 trunking system.at the end of all the conversation's the scanner would "kerchunk".i setup my br330t with the same system.now at the end of the conversation's the scanner just drop's the talkgroup softly and continues scanning.why the difference ?. it sound's much smoother.
torontokris
Toronto Canada
is the DETECT END CODE set to on /off?
I did notice the 396 was louder for beginning and end of activity
but double check your detect end code settings.
Taken from... http://myweb.cableone.net/marksscanners/330/330test.html
Set End Code (Motorola systems only) sets how the scanner handles the transmission end code sent by most Motorola systems. The default setting is Yes.
Scroll to 'Set End Code' and press E/yes.
Scroll to one of two settings and press E/yes to save and exit.
Yes- the scanner immediately returns to the control channel when it detects the end code.
Ignore- the scanner does not return to the control channel until the carrier drops.
scannersnstuff
thank's again torontokris.i swear i should start reading the friggin' manual's !. i know a lot,but have a lot more to learn.it definetly sound's better.
