lostdog19 said:
I'll most likely be using C# with the .NET Framework v2.0, as it contains a SerialPort class which will simplify the communication. Not sure what all I'll try and implement (mostly just for experimenting), as I haven't used a scanner in around 12 years, and my new one is currently in UPS' hands.
Oooh C#... nice. I really should learn it, maybe then I'd be able to understand the code snippets I get once in a while from rfmobile...LOL.. but everytime I try I end up not having either the time or the ambition to finish. Or both. Someday...
A tip on the unidens that may save you some frustration is that some commands require a query to get information back and some just provide it on their own. For example, there's a way to get the scanner to report back whenever an ID search hit happens. I'm sure it sounded like a good idea on paper but in reality it can be a real PITA, because the scanner doesn't stop and think "Hey you know what, I'm right in the middle of sending back a response to the LCD command, I should wait". It just dumps in right in with the rest of the outgoing information, corrupting the data you intend to put on your virtual display for example...
I griped and whined about it for years (since the 895 days) but no avail - those type of commands are still there. IMHO, the scanner should only spit back data when asked to by the host controller, not whenever it feels like it.
Just some FYI for ya. The protocol is far simpler than the nightmare GRE came up with for their scanners. My hat's off to Don Starr for being able to talk to those infernal gadgets - yeesh. I tried and gave up after a couple of YEARS of trying. I'm too spoiled by the ease of the uniden protocol.
-AZ
