Will check it out
I look on top of the screen when it happens to see if it says encrypt and it doesn't but maybe they are encrypted so logging software is something to try thanks
Will doIf you see the same talkgroup exhibit these symptoms, press the Channel Hold button and look for the encryption indicator on the top of the display. If it's partially or fully encrypted, the scanner will display it
You have to be real quickIf you see the same talkgroup exhibit these symptoms, press the Channel Hold button and look for the encryption indicator on the top of the display. If it's partially or fully encrypted, the scanner will display it
most of the time I see a talk group light up on the screen for a second or 2 but it never locks or
gives me audio, just blinks and then it starts scanning again. If It does this a second time I quickly hit channel lock softkey and the TG comes in loud and clear.
The scanner doesn't give you much of a chance to hit the hold. Even if you have a delay set.
Yes I use wide invert
Its trash throw it away and buy a 536hp with a yagiSDS strange problem
First I want to say:
1- I have my SDS-100 for 2 weeks now
2- I am receiving 4 p25 systems, 1 is an LSM system
3- I am using a ground plane antenna.
4- I have fantastic signals on all 4 systems including the LSM system.
4- rssi are -55 to -70 error count 0-5
The reception is superb no garbled voices solid all around
Here is the problem:
while scanning most of the time I see a talk group light up on the screen for a second or 2 but it never locks or
gives me audio, just blinks and then it starts scanning again. If It does this a second time I quickly hit channel lock softkey and the TG comes in loud and clear. It should stop scanning and open the audio but it doesn't I have to lock it with channel lock softkey to hear it. It happens about 70% of the time sometimes it scans and receives fine then the problem begins again.
It does this on all systems. There must be something to correct this problem I can't figure out what to try.
Please don't suggest hold time or delay time as it has nothing to do with either setting.
Thanks to everyone in advance.
It’s a way to fix that issue having trouble listening to one of the systems in the New Jersey it’s the new njsp new system
What u meanIf you're appending the entire system, it's probably bringing over all the sites from the entire state?
What u mean
The njsp system in nj
Yea it’s a state wide ststemI'm asking if it's a statewide system like Starcom is here in Illinois?
Only having issues on my sds100 scanners the other scanner is find I have a bc536 handheldYea it’s a state wide ststem
