In a earlier post I had the current go off from a wind storm several days ago. The current came back 8 hrs later. When I turned my SDS 200 on I no longer had my favorite list. I tried to reload the favorite list from Sentiel without any luck. All I have is full data base. I contacted Bearcat Wharehouse and they said I need a need cd card from them. They will provide a new card with my four county favorites for the cost of $150.00. I do not know how to format my existing card. As I said in the earlier post I am 77 and by no means a electronic person. Is this a fair price for the card and if so is all iI have to to do is insert in the scanner to have it back to normal operation. Sorry to bother everyone. Thanks Art PS Bearcat wharehouse stated that I could not use the old card.
A few words on encouragement.
I would suggest you learn the method for formatting your cards. 150 dollars is pure rip-off to provide a preprogrammed card, unless you happen to be a government entity. Are you sure they did not mean $15.00 ? That seems much more within reason.
Almost all cards that have failed on me have been either resuscitated or resurrected. The SDS200 (and likely the 100 as well) is very sensitive to read or write errors to the card and will cause the radio the balk. Some "read" errors got fixed by simply turning the radio off and then on again.
You certainly can attempt to use your old card--- I had one that failed 2 weeks out of the gate and after doing several of the "long" formats, that particular card has been working flawlessly for the past six months.
Having a spare card available should be the rule and not the exception, but even better, having a friend nearby with either the 100 or 200 can be even more helpful. I'm pushing up there is years as well, and yes, things that seemed easy now seem a bit more complicated.
Best of luck in your endeavors fellow old-timer.
