Uniden SDS100 Filters for simulcast
NS9710
Petersburg, VA
A friend of mine told me I'd need to use a "filter" setting for Simulcast systems, I am looking for a filter option for the Central VA Communications System [Lynchburg area], Hanover County, and the Roanoke systems. Thank you.
fredva
Virginia/West Virginia
From what I've read, there's actually no real guidance saying which filters to use for which situation. I think it is trial and error for the individual. My SDS-100 worked on my local simulcast systems using the default filter setting.
kruser
Central St Louis Cnty, MO
Everyone's results will differ. Me personally I use "Invert" on a simulcast system with closest tower about 4 to 5 miles from me
One of the two Invert settings generally work the best for me as well.
For 800 MHz systems, I find Invert works best for systems with strong or good signals as this filter attenuates the signals more than the others.
For weaker 800 signals, a Wide Invert works better for me as it has slightly less attenuation.
The 700 MHz band is mostly unused around me. For this band, I can usually set the filter to Off which does not attenuate anything and gives great results.
All bets are off for UHF 450 MHz signals. I usually can't pull a still strong but weaker signal out with an SDS series regardless of filter settings. I'm obliterated by nearby UHF signals and the 8 or 10 MHz wide front end used by the tuner chip simply allows it all in which wipes out all but the strongest. The available filters are way too wide to work for UHF in my environment. So my SDS models are used mainly for trunked scanning in the 700 MHz and higher bands.
iMONITOR
Silent Key
S.E. Michigan
For the North end of Macomb, County, Michigan, I use Wide Invert for monitoring MPSCS P25 simulcast.
