SDS100: Uniden sds100 over heat not working now
San antonio Tx 78216
#1
My uniden sds100 over heated and is not working after new firmware just days ago
The radio has no wear and tear to it
Upman need info to send back it to repair
And my second sds100 the link to the old firmware not to brick the other one
buddrousa
NW Tenn
#3
You need to post more information.
Not working is what?
Does not power up?
Powers up scans but does not stop on any channel or does not pass audio?
Have you tried a new SD Card?
What does the scanner do?
fxdscon
#4
What makes you think that “overheating” caused your scanner to stop working? What error messages did you see on the screen?
What symptoms happened just before it stopped working? What happens when you try to power it up now.... does anything show on the screen?
#5
no reception
From wfm a.m. narrow FM close call or anything else
Just got power to it's self only
tryed all
Nothing else but power to unit
I noted it's was very warm in my shirt pocket
Before I noticed no rx
Anne Arundel County, MD
#7
SDS100 radios all get warm. Probably has nothing to do with whatever your problem is.
Hard to tell what your problem is from your post.
SDS100&200/536/436/WS1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
Cuyahoga County, Ohio
#8
My SDS100 (which I bought a month ago) doesn't feel any warmer than my 436. I bought the external charger along with the scanner and only run off of battery power. Is it because I don't charge my battery in the scanner and never run the scanner off USB power that I don't feel anything?
