SDS100/SDS200: Uniden SDS100
Dougins554
Im from New Brunswick Canada, YORK county, now I have just received my SDS100, There are no frequency numbers for the fire talk section, Can I just add the DEC numbers into the scanner to hear them or the site ID, need some help im a little slow at this lol. thanks
CT
I'm not familiar with the system, but if it's a "Trunked System", You need to enter the frequencies and the Talk Group ID to hear the system.
The number in the "DEC" column is the Talk Group ID.
Dougins554
When I look it up all I get it the talk group is there are no frequency numbers, so can I just add the talk group ID into the scanner
Whiskey3JMC
Just another pesky scannist
Simulcastylvania, TE
Hi & welcome to the RR forums!. I'm assuming this is your system of interest. Easiest way to program the scanner is by using Uniden Sentinel
Not sure what you mean by this but if there are talkgroups that haven't been identified in the database, you can certainly enable ID Search so the scanner can scan through unknown talkgroups
jonwienke
More Info Coming Soon!
VA
No. You have to look up the system site(s) near you and program them first. The scanner scans sites, not talkgroups.
donc13
Grand Junction, CO
Do it the easy way, set your zip code and set the service types you want to listen to. The scanner will do the rest.
