RadioactiveWave
Was wondering a question what type of mobile antenna preferably magnetic base, would be best suited for the uniden sd200 to cover most emergency frequencies example fire EMS police@
Thank you I'll have to try that, another question if I may would d130j original diamond antenna, link below,Amazon.com
Amazon.com: Larsen NMO150-450-800 Tri-Band Nmo Antenna
Amazon.com: Larsen NMO150-450-800 Tri-Band Nmo Antennawww.amazon.com
You'll have to get an NMO mag mount base with a BNC termination.
In my opinion, it's the best Tri-Band on the market.
I have this antenna as well. It does a good job in my metro area, as well as when I go out west of DFW where Vhf-high systems predominate.Amazon.com
I have that exact Diamond antenna in my attic and can pick up signals pretty far away. Just the way it is, no trimming. I only use it for receiving.Thank you I'll have to try that, another question if I may would d130j original diamond antenna, link below,
Be good for a stationery antenna 📡 ?D130J - Diamond Antenna
www.diamondantenna.net
All good advice !! I started using LMR-400 and like it better at higher frequencies. For a couple of $$ more I have the dealer install connectors especially at the outdoor end, with a weather boot !!!!! For the length of time it will be used the extra $$ comes out to nothing. 73 to all MichaelThe Diamond antenna is a good choice. It’s an antenna that plays well over a wide frequency range… including all that the SDS200 is capable of receiving. It’s a non-gain “discone” antenna. When I see “discone I think “non-gain”. But it’s omnidirectional meaning it receives equally well in all directions as opposed to gain antennas such as log periedoic (yagi) or “beam” antennas that have some gain but are directional, which means you need a rotator to aim the antenna in any given direction. (However, I have a yagi to listen to an airport that’s on the fringe of my reception area in an attempt to improve reception of the airport tower, with a rotator, but find I really don’t need a rotator as it receives pretty good off the sides for other services I listen to… I simply point it at the airport and leave it there.
If you use the discone omnidirectional antenna suggested and the reception isn’t as you expect, try first turning it a bit before you think about a directional antenna. Sometimes a slight turn of the antenna will get you out of a “null”, a dead spot inherent with any antenna design that uses radials. But it’s very uncommon to experience this-I haven’t seen anything ever posted and have never noticed it when I tried it… just something about the physics, the propagation of radio signals…
The amateur radio operators have a saying about transmission… if the transmit signal isn’t getting the job done, try doubling the height of your antenna before doubling your power output. In most cases that’s all that’s needed. This advice also plays well for reception. So, if your antenna is at 20’, increasing it’s height should help before looking at gain antennas.
While we are on the subject choose carefully your feedline coax. I use Belden 9913. It’s a thick coax but I use it for most of my run into the house (50’). When I get it to where it comes into the house I use a smaller diameter coax (a pigtail) which is more manageable. Just keep the pigtail distance as short as possible. They also make thinner coaxes that play well and eliminate the need for a pigtail. Coax is measured in a loss of signal over 100’. The higher in frequency you go the more signal loss becomes a problem. Using RG58 is great for CB at 27 MHz but is terrible for the UHF band (450 MHz) and higher (700, 800, 900 MHz ranges. My advice would be to call a reputable dealer such as Scanner Master and talk to them about this. They know what’s available for the bands you hope to monitor and can recommend a suitable feedline. It does us no good to spend good money for an antenna and scanner only to find your reception sucks due to using the wrong coax/feedline.
Not for anything below 800mhz unless the transmitter is in your back yardYou will find a paper clip works just about as well as any of these high price antennas.
Try it. Perfectly tuned antennas are needed for weak signals. Transmitting is a totally different story. For shortwave it definitely helps to have at least a 1/4 wave antenna but for VHF/UHF, I never, ever noticed any difference. I use a HDTV antenna for my base scanner, paid $5 for it. Works great.Not for anything below 800mhz unless the transmitter is in your back yard
zero experience
