Uniden SDS200 Stopped Receiving Traffic
werinshades
Chicago , IL
Nothing.
it just beeps and does nothing. So I have to hit the menu button to continue to scan...speaking of which
NO radio traffic even though the Whistler is active,,,
Back to square 1
Just so I'm following along..Monitor and Download are both ON under Set Scan Selection in the scanner?
Menu...Set Scan Selection on the scanner I'm referring to.
Also on the scanner...Menu..Favorite Lists...it's showing up there?
FireLt111
Assistant Fire Chief
Ashland, Kentucky
Ok, I am on that page (in the scanner) I do not see Monitor or Download...this is what I have
Manage Quick Key Status
Set Nationwide Systems
Select Lists to Monitor
Set All Lists Off
Set All Lists On
werinshades
Chicago , IL
Set All Lists Off
Set All Lists On
Is the Favorite List in the Select Lists to monitor?
Icanhearit
Bay Area, CA
If you have per post #61 screenshot -like setting checkbox and post #82/83 screenshot and did write successfully to the scanner, download and monitor are both on, no problem there.
Though I would write to the scanner, also use window to eject the mass storage to make sure the content did sync to SD card before recycle the scanner power button into scanning mode.
What's your scanner zip code and range now set to? if in doubt how to, see
start around 1:10 minutes
werinshades
Chicago , IL
No.
the only thing in that page is:
Full Database
Search with Scan
Boyd County E911
Now is the Boyd County E911 what you're asking about?
No...I told you before to Delete Boyd County.
So...back to Sentinel...the Favorite List wasn't uploaded properly to the scanner.
Icanhearit
Bay Area, CA
No.
Full Database
Search with Scan
Boyd County E911
he is asking, press menu ->set scan selection -> select lists to monitor->
Now check if your want to monitored list is set to on? (and set the rest to off for now)
werinshades
Chicago , IL
[/QUOT
Edit...Edit Profile...under the Favorite List I sent...Download ON... Monitor ON.
Under the File tab..Save.
Under the Scanner Tab..Write to Scanner.
Plug in scanner...Mass Storage Mode..Yes/Enter....
Write to Scanner...unplug scanner..let it boot up and you should hear traffic.
