Uniden SMA-BNC connector
Bolt21
Spark Chariot Driver
Punta Piñal
I just boogered up the connector on my 396T. I'd like to replace it with the same Uniden-type style, and I've found some connectors on eBay that are similar to the original Uniden part. The only difference is the bottom (the SMA male end). The Uniden connector has a slight recess/bevel on the bottom outside edge. The ones on eBay are completely flat (descriptions say they'll fit Yaesu). Does anyone have any experience with these as far as whether or not they'll seat properly on a 396 or similar radio?
I know I can get one from Uniden, but I'd rather not pay $15+ for something I can get for $4-5 and still do the job.
Thanks.
betta
24309 Linda Ln. Porter, Tx. 77365
Sma plug to bnc jack adapter
i just boogered up the connector on my 396t. I'd like to replace it with the same uniden-type style, and i've found some connectors on ebay that are similar to the original uniden part. The only difference is the bottom (the sma male end). The uniden connector has a slight recess/bevel on the bottom outside edge. The ones on ebay are completely flat (descriptions say they'll fit yaesu). Does anyone have any experience with these as far as whether or not they'll seat properly on a 396 or similar radio?
I know i can get one from uniden, but i'd rather not pay $15+ for something i can get for $4-5 and still do the job.
Thanks.
bolt21:
Mouser electronics has the conn. In stock. They are about $6:00 plus
shipping. These are amphenol usa made. I just ordered me some this week.
The part# is 523-242102.
Betta
Bolt21
Punta Piñal
Thanks, but that's the "alternate" style I'd prefer not to use. Your internal jack is more prone to damage if you drop your radio and it hits the connector. I'm looking for the original Uniden-type style, and have the above question about how well it works.
mke65
Seattle, WA
Also HRO has one made my Watson. Great quality as to be expected by Watson. Also it's all black so it looks much better.
KF4JYE
Upstate SC
Universal Radio has an black adapter similar to the Uniden one, for $10, made by Diamond. Link:
BNC Adapters
Order #0292
Item BNCJ-SMAP
Works great, is shorter, and looks better than the Uniden adapter!
garys
Texas
I've used the generic ones before without a problem. I got this one on Ebay, but they also have silver ones. They even have a tacticool black one listed.
Oldglide
Metro Chicago
Uniden SMA to BNC connector
Bought one from ebay looks exactly the same, big knurled base, gold. Works fine but doesn't screw all the way down to the top of the radio, threads are exposed. The threaded area on the Uniden connector is about an 1/8" longer.
garys
Texas
I noticed that after you mentioned it, but it only took me about a minute or so to dig through my various hardware and find a washer that works perfectly as a spacer. I'm sure that they are available at any hardware store.
The tacticool black one on Ebay comes with it's own spacer.
jmusto
Sma-bnc
I bought one from Ebay. It does not seat all the way like the Uniden adapter. The SMA connector is not as deep so there is about a 1/16" gap. You may be able to solve this with a washer but I haven't tried that yet as the adapter just arrived.
Thanks.
Highpockets
Toms River, New Jersey
I've read where others have used a rubber O ring and get good results.
W4KRR
Coconut Creek
I have several different third party BNC to SMA adapters. Not all of them screw completely down onto the radio, like others have pointed out. A small flat rubber washer between the radio and the bottom of the adapter will close the gap. I use washers from Diamond (or is it Comet?); some of their portable antennas are supplied with these washers, which is what I use.
