Uniden USB-1
VA3JWO
Madoc, Ontario
I'm using a uniden bcd396t, and i want to program it on my computer, which is a mac and uniden sends me a SERIAL cord Which is for computers from the STONE AGE....... Come on uniden, wake up and smell the coffee.... Anyways, getting back the the scanner cord, I was searching around quite a bit for the USB- 1 cord and its priced at $44.95 CANADIAN..... What a rip off. What my question is, is it a good idea to get a Serial- USB adapter which is not made by uniden and is approx. $15 at TigerDirect? or does it need to be a special one from uniden?
I ordered the USB cable from Scanner Master and downloaded the firmware for the cable. It was only $29.00. It should be here soon. My 346xt is two firmwares behind, but my 15x is up to date.
PL2303_windows7.zip is the download. My 346 has 1.01.09 since then 1.04.00 & 1.05.00 have come out. Total for the cable with shipping was $33.70. Hope this helps you.
VA3JWO
Madoc, Ontario
i would buy it from scanner master, but i will have to pay customs/ duty fees, and lots of other stuff on top of that..... i was just curious if a cheap serial- USB adapter from a local computer store will work
Al42
Long Island, NY, USA
It depends on the chip used in the adapter and the computer you're going to use it on. The Aten UC232 (sold by others as GC-232) has a Mac driver for OSX (and drivers for ealier versions).
If you can't get a driver, the adapter is useless. For instance, the Belkin F409 is one of the better adapters, but Belkin refuses to come out with 64 bit drivers. So I'm using a not-as-good GC-232 and Aten's 64 bit driver. Small company, but they think of the customer.
Clark
Venice, Calif
You stated that you are using a MAC, what program do you intend to use to program the scanner after you have a USB adapter or cable?
Clark
