There you go. Simulcast performance on MPSCS.
New Uniden BCD536HP Simulcast Performance on MPSCS - YouTube
Video of a BCD536HP in action on the Indianapolis/Marion County DPS 800 MHz P25 LSM CQPSK simulcast system.
Uniden BCD536HP scanning IDPSC (MECA) - YouTube
That was not very good at all the simulcast break up was bad at times from the cars and dispatch or is that good for that system?
Out of all the reviews so far the IPDSC system is the only one struggling so far. From the half dozen other reports the reviews have been the same or extremely positive. I wouldn't base my buying decision on this unless I live in that area. There are more reports to come as users get there radios. I like to see reports from Atlanta, Phoenix, etc. The IPDSC system may just be a total nightmare to monitor.
any simulcast system is a nightmare if you have to put up with it...so either you have fixed the problem or you have not...real simple....for $600 bucks..Uniden will not come out right and say they have....have they?
From YouTube description:
"The scanner at this point was right out of the box with no adjustments to the settings."
Does that mean no firmware update was performed?
I think Uniden has said they improved simulcast on several occasions. For me, it has completely. The MetroSafe system in Louisville has been a nightmare on my Pro-106 and Pro-197. When mobile, I was lucky to get half the transmissions on either device. On the 106 I had a 800mhz antenna. On the 197, I had a decent antenna I bought from a local radio shop that was designed for 800mhz.
On my drive back from the Ham Station in Indiana, I stopped and did a quick power on of the BCD536HP and using the stock antenna, I set it to scan just MetroSafe. From the Indiana line thru the western part of Louisville then from north Louisville to south Louisville, I did not have the first garbled transmission. The audio was also much clearer and sounded just like it was coming from one of the portables the officers carry.
I am very impressed.
I believe performance will vary by system and also user setup but for the vast majority posting, it has been a great improvement.
I'm glad your satisfied with this unit...and the money you spent on it...I hope to see more reports that are positive in nature...I will still wait and get the full review ...thank you
You are correct... Uniden has never stated that they have corrected, solved, enhanced simulcast permronace in any way.
UPMan specifically stated he would not comment on it and that users would have to decide for themselves.
My point is the same as your... if Uniden HAD made improvements to simulcast reception, they would have made it a huge selling point. But they have not.
So the only conclusion I can come to, is that they "maybe" made some small tweaks that helped a little, but not enough for them to be confident enough to declare any of these possible enhancements any sort of fix.
