BCD436HP/BCD536HP: Unidentified BCD436HP Muted
tmcclain73
Somehow my Uniden BCD436HP became muted. I was trying to listen to the OHP and pressed System, Dept, Chan so I could listen to that specific dept. When I went back scan everything was muted. I must've pressed mute at some point but I have no idea which one that is as it’s not labeled. Any advice would be appreciated.
Thanks,
Tom
dave3825
Suffolk County NY
The scanner does not have a mute option. Does is show as scanning, and can see it stopping on channels? It could be a few things. Do headphones work?
Ubbe
Stockholm, Sweden
Push Channel to do a hold, enter a frequency with a decimal and push Channel again, push function and then click on the rotary controller and the display should say SQUELCH LEVEL. Then turn the rotary to 0 and you should hear noise. If not, then push function and the replay button to start a recording.
Connect the USB cable to scanner and PC and select mass storage mode on the scanner and play that recorded file from the SD card, it will be in the BCDx36HP/audio/user_rec folder.
If that has sound then the speaker, audio amplifier, earphone connector could have a problem. But if that file also has no sound then lay the scanner on its back and power it off. Hold in buttons 2-9-DEPT while powering on and it will be reset and the display should indicate it. You can probably do the same by going into the menu and Settings and Reset User Settings. Do that Channel+freq+Channel and set SQ to 0 and check if you get any sound. If you do, then program the scanner again from Sentinel.
/Ubbe
tmcclain73
It does show as scanning and stops on other channels as if there’s traffic. I don’t use the headphones, unfortunately I don’t know where they are. If it helps the buttons also don’t beep when pressed.
RandyKuff
Lorain, Ohio
Your volume didn't get set to zero (0) by chance...
Push down on the rotary knob once and look at the bottom of the screen and make sure it's not set to "0"
tmcclain73
I already checked the volume to see if it was turned all the way down. It’s on 10.
RandyKuff
Lorain, Ohio
You may want to read this...
RandyKuff
Lorain, Ohio
It's not hard to open it up and do the checks mentioned in above link...
