Unidentified Freqs
trashman43
Kentucky DB Admin...
Kentucky
Looks like the Unidentified Freqs thread got pushed down and didn't have any replies in a certain time period and is now locked. So here is a new unidentified Freqs thread.
Signal is S-4ish in Central Ky on discone at about 40'
461.6125
DCC 15
TG 1
Slot 2
RID's 10,11,28 so far
Here are a couple of possibilities.
CORNING INCORPORATED461.61250000WQCU961AHARRODSBURGMERCERIG
BARTON BRANDS LTD461.61250000WPCR562ABARDSTOWNNELSONIG
Remington12G
GØT AES?
461.4125
DCC: 11
TG: 5
Slot: 1
Posting here because this does not match the talkgroup that I originally found for the freq before.
Baptist Healthcare? Very weak on Northside of Lexington, strong at Fayette Mall.
Remington12G
GØT AES?
452.8000
DCC 1
TG 3
Slot 1
RID 7 so far (Possible Patch to another system, same RID every time, different voices.
Only picking up half of the convo. Signal 5 or so coming into southern Scott County
Remington12G
GØT AES?
Very Active. Possibly in the Georgetown Area, asking about what extension to call and referring to each other by names. Same TG, Same RID every transmission.
Edit: This user(s) has multiple channels as a employee said "I thought you were on channel 7"
Remington12G
GØT AES?
452.8000
DCC 1
TG 3
Slot 1
This has been identified as Lakeshore Learning Materials Distribution Center in Midway, KY just over the Scott/Woodford County Line.
Remington12G
GØT AES?
464.3000
DMS
CC: 1
TG: 5000
Slot: 1
Monitored from Southern Scott County. The band is wide open currently so It could be Northern Kentucky or Metro Louisville. Receiving at about a 7/10 on signal.
Charlie1068
Houston, TX
FCC database for northern Kentucky and Louisville show that frequency as Amazon in Hebron near the CVG airport licensed for 40 watts or it’s a DMR channel in Louisville licensed for 100 watts
Remington12G
GØT AES?
155.955
P25
NAC: $001
TG: 1
Monitored from Southern Scott County. Not the first time picking this up, sounds like LE or a service dispatch channel. This is not the City of Georgetown in Scott County.
Remington12G
GØT AES?
Monitored Further traffic, this appears to be Maysville, KY Law Enforcement. The dispatcher advised "Local to Maysville on that tag". The dispatcher also dispatching calls that are in the city limits of Maysville and other keywords such as "Dispatch to Maysville 216".
trashman43
Kentucky
Some unidentified Fed frequencies logged using Pro 197, Win 500 and discone antenna from central Ky during the week of Ky Derby. (Not necessarily used at Derby)
166.08875 NAC 250
167.3375 NAC 540
170.5000 NAC 788 (Id'd) USFS
170.8125 NAC 59F
171.1625 NAC 574
ecps92
Taxachusetts
166.0875 $250 has been around for awhile and never ID'd - reported since 2008 ish
170.5000 - any idea which Forest ?
170.8125 - false hit or did FBI Louisville change from $167 to $59F (how many hits?)
171.1625 $574 - NPS Natchez Trace National Parkway -LE- Repeater net
166.08875 NAC 250
167.3375 NAC 540
170.8125 NAC 59F
171.1625 NAC 574
trashman43
Kentucky
Shawnee National Forest
U.S. Forest Service
SNF Williams Hill
170.8125 - false hit or did FBI Louisville change from $167 to $59F (how many hits?) not sure, several hits on same day
171.1625 $574 - NPS Natchez Trace National Parkway -LE- Repeater net thanks, I'll add it to my notes
Remington12G
GØT AES?
464.3000
DMR CC 1
Slot 1
TG 5000
Coming in about 3/10 into Southern Scott County. Possibly Lexmark In Lexington however as soon as the DMR signal dropped analog traffic started pouring in. Unknown at this time
trashman43
Kentucky
460.525
Info from DSD
DMR (MOT) BS DCC:3
Radio Check; Tgt=1129 Scr=9111
Radio Check; Tgt=1199 Scr=9111
Radio Check; Tgt=1156 Scr=9111
Received in Marion and Washington County areas but probably not local.
FD101
464.03750 - DMR CC 5, TG16777215, Fritz Farm Admin?
Received in Lexington Metropolitan, Tates Creek Section.
FD101
151.4450 - NAC 003
S2/3 on AA Highway in Bracken
Possibly an Ohio agency
