Unidentified signal at 120 mhz
sumanta39
Hi guys,
So I was playing with a rtl sdr dongle lately and came across a strange signal exactly at 120 mhz. I am using gqrx for sdr side. Any idea what it is? Here is the gps info of my location if relevant:
Latitude:31.70677465 N
Longitude:76.52492523 E
Sea level: 882 M
  • Screenshot from 2015-07-02 23:45:14.jpg
moonbounce
Just a thought, try switching to WFM and see if you hear anything, it looks like an FM signal?
D
DaveNF2G
Guest
Does it seem to be modulated or just a "dead carrier" type of signal? Being on an exactly even MHz, it could be a birdie.
sumanta39
Nothing but hissing sound by WFM
Hi guys,
Thanks for the prompt reply. Tried the same with WFM but nothing but hissing sound. It does seem like a dead carrier like signal as Dave has said but when I zoom it I can see some activity. However when I swipe across the AM frequency selector over the signal I can here some whistling sound. Also I found similar signal at 480 mhz (480 = 120 * 4 does it ring any bell?? ) and it is stronger. Here is the screen shot of the same in the attachment.
sumanta39
It was not from the antenna indeed!
When I unplugged the antenna it was still there only without the harmonics. So it was noise indeed..
Arminius75
120 Mhz
Are you near an airport? I had the same problem and found that I am picking up Dulles main tower 120.250Mhz.
