Unidentified talkgroups on BMR Fleetnet Zone 3
mikewazowski
Staff member
Central Ontario
Before posting your unidentified talkgroups, please check the database to make sure they haven't been already identified:
http://www.radioreference.com/modules.php?name=RR&sid=3511
Use this thread to post and discuss talkgroups that are yet to be identified.
Do not use this thread to discuss how the system works or how to program your scanner for it. Start a separate thread for those topics.
In order to keep the thread from becoming unwieldy, I will delete any posts not fitting the topic.
hodet
Timmins, Ontario, Canada
Timmins MOH/Hospital?
Logged and Recorded two talkgroups last night in Timmins.
36480
36464
Never seen these two but from the recording obviously an ambulance on the scene.
Heard that the different zones use the same talkgroup ID's in some cases.
I found them in zone 1 as follows
36464 8e7 A MIS SPR Mississauga Hospital Spare Hospital
36480 8e8 A AJAX Ajax/Pickering Hospital Hospital
mikewazowski
Staff member
Central Ontario
Yes, same talkgroup id's for the same purpose.
What you've found are two of the hospital talkgroups. Chances are they're located in the Timmins area.
Probably not an ambulance onscene but one enroute to the hospital.
Here's the general flow:
Ambulance is enroute and requests a patch with the base hospital.
CACC assigns a TAC talkgroup and tells the ambulace to switch to the TAC talkgroup.
CACC call alerts the hospital (you can see the call alert with trunker) and patches the TAC talkgroup with the hospital talkgroup.
The hospital answers the call alert and the patch commences.
Once done, the ambulance switches back to the dispatch talkgroup and the CACC takes down the patch.
hitsfm
timmins
2 talk groups
36464 is ambulance from matheson talking to tdh
36480 is iroquois falls ambulance
39664 is a new one but missed it
