Unification pager as a scanner
admin256
Love the audio quality of the unification pager. If I listed to lets say 6 different agencies can the unification unit be programmed to act somewhat like a scanner
Thanks much
emtLarmy15
Pocomoke City, MD
As long as they are on the same p25 trunked system or they are all conventional and in the bands that are in your pager.
N6ML
"Somewhat", yes. If they are all talkgroups on the same P25 system/site, or all conventional channels, you can create a "scan" "channel" for it... but you can't enable/disable TGs within the list on-the-fly, or lock noisy ones out, or scan multiple systems/sites, etc.
Illinois
Thanks much
All depends on how you set it up, the unication will only scan the channels you put into each knob position. You can't lockout channels like you can with most scanners but the positives outway the negatives, this is a pager after all.
CanesFan95
Was Homeboys-Scanna
Banned
FL
I believe there's also no scan delay and no hold / resume scan button. So if you're scanning, the radio'll quickly jump to other active talk groups without waiting a few seconds for a reply first.
LEH
Yorktown, Virginia
I use mine as a monitor to augment my scanners. If I can, I have the system (or dispatch area) I am currently physically in running on the G5.
As a receiver it is one of the best on the market. As a true 'scanner', well it is a pager with a broad reception capability for one system.
