SCOTTER
Can I uninstall the 111 update and go back to 110 because my 396xt is a mess as far as err rates and I have tried to get it up to the way is was before with no luck. If so how Thanks
I think you are right, that was the gist of the update. I don't think it had any effect on me. I don't think it was meant to change anything for systems that use P25 voice, just actual P25 LSM. Even fiddling with the hidden adjustments I have to go quite far out on the settings to hear any degradation in voice quality.....It must only improve a certain type system....
Are there any links up yet for the 1.10 version?
I guess you skipped over post #2 above?
Is that the updater uses a key Im a lost I have the 2.0.0.7. updater and is the key in the battery compartment
If I do this-
Update--Update Firmware
Update --Update master HPDB
Homepatrol--Write to Home Patrol
Does this put the new update about the simulcast system, in my Home Patrol?
I do not want the up date about simulcast systems.
I only want to update the frequencies.
If I do this-
I was mistaken. I do not have 2.04.01 in my HomePatrol. Sorry my mistake. I have 2.02 (revision 04).
If I install 2.04.01, then that would put the new update, about the simulcast systems in my Home Parol.
Is that all that 2.04.01 does?
I understand NOW. I think.------ Do not updating the firmware, if i dont want the update about the simulcast systems.
