Uninstall firmware update from pc
rbd8704
Hi Folks,
I just have one question about firmware updates for the BCD396T. I just updated the firmware
Version 3.00.00 to scanner with no problems and now I would like to remove the desktop shortcuts
and the software from PC (BC_VUP & BCD_ESN_Loader_V1_20_13) using control panel uninstall programs.
Is there a problem with doing this? Are any of these programs used for future updates?
Regards,
Bob
bwilborn
Evans, CO
You might want to keep BC_VUP installed as it will be used if further firmware updates come out, but you will do no harm by removing any of those programs or files from the PC.
-- B
rbd8704
Thanks bwilborn, that's what I thought. I had a hunch BC_VUP might be used for future updates. I'll
go ahead and remove BCD_ESN_Loader_V1_20_13 from PC.
torontokris
Toronto Canada
good advice you dont need V1_20 anymore... also you can probably delete V3 (if its there as well on your desktop) since you already have it on your scanner.
worse case you can re-load any of these from Uniden
rbd8704
Thanks once again V3 has also been deleted. This has always been a question I've
wondered about with all downloaded programs. I just want to recover hard drive space and clean
up the desktop icons.
Bob
