>> I can hear other frequncies in the count plus Mecklenburg County is crystal clear also.
You're comparing potatoes to tomatoes. Mecklenberg County is primarily 800 Mhz ... in the right location, a paperclip will work well as an antenna.
Which Union Co frequencies are you comparing ? 453.850, 453.2875 and 453.200 (Cane Creek Park) are all licensed for narrow band emissions.
453.525, 453.925, 453.025, 453.125 and 460.100 are all licensed for normal 20 kHz bandwidth.
A repeater transmitting a narrowbanded signal will sound differently than one emitting a wider-bandwidth signal. And most older scanners were not designed to address the narrowbanding issue.
I would agree with David, though, that the first step is to make sure something regarding your scanner / monitoring area hasn't changed. PCs and PC monitors can create interference ... particularly some laptop power supplies. If you are using an outdoor antenna, check the coax for breaks, a bad ground, tight connectors, etc.
Move the scanner to a different area of the home, and check reception again.
Sometimes, a new appliance or piece of electronic equipment elsewhere in the house can create interference. If you can hear "static" on the frequency all the time when the squelch is turned back - even when no one is transmitting - try switching off the house's circuit breakers one-at-a-time, and listen for the sound to disappear.
Two other circumstances come to mind that will affect reception on 453.850, but not all the time. If you lie in the eastern end of the county, you'd probably hear Moore County Sheriffs as often as UCSO, which interference issues when they are both using the frequency simultanteously.
And Union County Schools uses 453.8375 as part of an LTR system, so you might get some adjacent channel interference during school hours, depending on your location.
