Union County
Joesan8611
I’m lost. I purchased some boafengs that are tri hand and got my GMRS license thinking these would help me listen to everything going on in union county specifically Mountainside Nj and surrounding towns. Seems what I purchased isn’t helping one bit. Can someone point me in the right direction.
APX8000
Sarcastic Member
AES-256 secured
Almost all of the agencies in Union County use the NJICS P25 trunked radio system. You will need a scanner capable of receiving TDMA/Phase II, which is pretty much limited to the Uniden SDS-100/200 or the Unication G4/G5 in order to handle LSM.
You CAN monitor some of the conventional analog stuff in Union County with your Baofangs 🤮 such as EMS paging, Fire Mutual Aid, etc. but even agencies not on NJICS like Clark are using P25 which your Baofangs are incapable of.
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
Joesan8611
lol guess that means I get to buy a new toy. Question, does that also go for a Motorola HT1250? Happen to have a spare one of those. I’m guessing that’s also not going to work cause it can communicate on some of the same setup frequencies that my baofengs are on.
Tac-1
Linden, NJ
You can still listen to Union County
453.150 WPWC995 RM 127.3 PL UCFMA Main Fire Mutual Aid Dispatch FMN Fire Dispatch
453.050 KQT944 RM 162.2 PL UCFMA Ops2 Fire Mutual Aid Ops 2 FMN Fire-Tac
460.100 KKS96 RM 162.2 PL UC EMS/MICU Local EMS/MICU Dispatch FMN EMS Dispatch
460.450 KKS96 RM 162.2 PL UC EMS MA EMS Mutual Aid
You can also hear SPEN 1 and 4. Check the RR database and other non-p25 frequencies you can look up more in the database.
APX8000
Sarcastic Member
AES-256 secured
HT1250 is not trunking capable or P25 capable.
