Unit ID 1252XXX
pro106import
Milford, Ct. perched high above Long Island Sound
Been seeing a single unit ID 1252XXX on a DEA simplex frequency. Not a false trip. Two different radios, several times, along with other units with the normal 214XXXX ID's I usually see are coming up on the same freq. Any idea what agency? Or maybe someone programmed the radio wrong? Never seen a unit ID close to 125XXXX
sflmonitor
Sunny South Florida
The only federal ID numbers that I have seen in this range have been aviation assets. The ones that I've seen are in the 13XXXXX range.
pro106import
Yes thank you for that info. Another member also has notified me that he has logged an aircraft using that ID prefix. Usually you can hear the notorious aircraft background noise that we are all familiar with when transmitting, but did not notice it during this event. But who knows. It was sure coming in strong enough to be a possibility.
Bob
