In Sentinel
Edit Profile (x36 model profile only) SDS100 doesn't have this setting.
Select Display Options tab
Under Display Mode:
Select "Mode 2" (Unit ID Mode)
Close the window.
Save the setting changes.
write changes to radio.
Unit Id's must be added to your programming in order to see labels (Unit Id Tab in Sentinel)
only exception is NXDN ID's can be displayed because the text data is transmitted with the voice and if properly decoded will display without programming. Any other system type must be manually added. Otherwise you only see a number, you have to assign a tag to each UID. (Provided you understand who's talking)
Ex: from my Chester County P25 UID programming
211011 Union Lad Mob
211012 Union Eng4 Mob
211013 Union Eng1 Mob
211014 Union Tank Mob
211015 Union Amb1 Mob
211016 Union Amb2 Mob
211017 Union Amb3 Mob
211018 Union Eng2 Mob
211019 Union Res Mob
211020 Union Utility Mob
211021 Union Brush Mob
211022 Union Sqd/Bt Mob
211023 Union Mob
211024 Union Dpty Mob
211025 Union Chief Mob
211026 Union Mob
211029 Union Mob
211500 Union Chief Port
211501 Union Asst Chief Port
211502 Union Asst Chief Port
https://wiki.radioreference.com/index.php/Chester_County_Emergency_Services_Radio_and_Unit_IDs
I see Bucks County doesn't have a nice wiki set up yet..
https://www.radioreference.com/apps/db/?sid=7699
Some systems have a wiki page... They are created by RR Users and are an invaluable resource if taken advantage of...
I hope this helps....
