dfw1193
See also page 42 of the user manual where it explains the difference of explicit and implicit systems in relation to the bandplans and the need to set a custom bandplan in the scanner for an implicit system while explicit systems obtain the bandplan from the control channel. So if you add bandplan info manually to the 536 the reason it gets erased is that you did not put it under a custom bandplan when you manually entered it. Thats my guess.
How that relates to how its in sentinnel I dont know maybe you should try a different profile for the 536 as opposed to the 436 and experiment some, maybe Upman can explain it better since he is more familiar with the use and programming using sentinnel software.
What or how does it show up when you put it in the 536 and its working then create a new 536 profile in the software and do a read from the 536. Then do the same for your 436 and compare the profile info files with a text editor to show any difference maybe you can see how the software differences are between the one that retains them and the one that erases them, just an idea.
