Unitrunker 1.X Data to 2.X
Coolant113
Warren County NJ
I am looking to upgrade my Unitrunker from 1.X to 2.X so that i am able to use Trunking Recorder. Is there a way to import all of the radio tags that I have done into Unitrunker 2.X?
GTR8000
NY/NJ Database Guy
BEE00
It's automatic. If you install UT 2.1 on the same PC where 1.x was already running, it'll reuse the data files. I would make a backup of them first just in case things don't work out.
C:\Users\<USERNAME>\AppData\Roaming\Unitrunker\
Also keep in mind that 2.1 only works with certain dongles. There is no support for scanner control or discriminator taps.
Read here if you haven't already before proceeding: http://www.unitrunker.com/v2/
Coolant113
Warren County NJ
Thank you for your reply and good information. Does the RTL-SDR V3 work with 2.1?
maus92
The OP
Yes, but understand that you may need two or more depending on the bandwidth of the system and how busy it is / how many simultaneous conversations you want to record.
ecps92
Taxachusetts
What is/was the latest version to work with the discriminator tap ??
