Unitrunker and a BR330T
kd7ckq
No. AZ
I am having problems controling my BR330T. Below is my settings.
When I run Tuner it will control it. But, just using Unitrunker. I cannot get it to work right.
Bryan
kd7ckq
No. AZ
All my scanner shows is 'REMOTE MODE, KEYPAD LOCKED.'
I will see activity and nothing happens with the scanner. I tried this with a BCT15, BC246T and BR330T.
kd7ckq
No. AZ
Tuner will control the radio with the following settings.
MODEL DATA BITS
BR330T 8
PORT STOP BITS
COM1 1
Buad Rate PARITY
115200 None
I tried different setting with Tuner and it will not control the radio.
Same settings in Unitrunker [R]eceiver, just lock the radio up.
[L]isten settings are the same as above except it now allows me to change volume and squelch. Plus Park Mode settings.
Scanner beeps when a change is made but, immediately goes back into 'REMOTE MODE, KEYPAD LOCK' and stays there regardless of what activity Unitrunker sees.
kd7ckq
No. AZ
Solved it! I had all the TG's set to Listen: NO.
Time for a TIME-OUT. All is now working great.
Bryan
Hi Bryan;
Under the [L]isten options, you can also set "Listen=ignore" telling the program to ignore the per-talkgroup and per-user Listen Yes/No settings.
