Rick,
I tried to follow your directions too, but I seem to be missing something.
I've determined that the best fit (by using my PRO-97) for one of my local systems is using the following block size codes:
0 = S01
1 = S01
2 = S02
3 = S02
4 = S03
5 = S03
6 = S04
7 = S04
I went to input the information, but it appears that you not only must put in the min/max Id's, but also a min/max for agency, fleet, subfleet and io. Where could I find the breakdown to input this data that is requested. My PRO-97 doesn't give that to me, but it allows me to experiment with the sizes, based upon the block size code selection.
I went back to the wiki to see if there was breakdown like you are suggesting, but I didn't find anything. I did, however, see under "Determining Motorola Type I Fleetmaps" that it breaks the Lower and Upper ID's down by block. If those are valid across the board, what would one need to put in the min/max for Agency/Fleet/Sublfeet/io?
If those are not generic numbers for the ID's, is there a breakdown chart or something, somewhere?
Can you show an example of the filled in screen for the below screenshot?
Thanks for the help,
