Unitrunker and Vista Fix update
lowboy654
DB Admin Member
Northwest, WA
well I thought I would ask here Rick if there is a fix for unitrunker use with Vista so that I dont have to keep reading the long thread that is going on.
Thanks, Ken
rdale
Lansing, MI
What you should do is check the download site and see if there's a newer release than what you downloaded... If not - I'd say... no.
Go-24
Indiana
That wouldn't necessarily indicate a fix for the vista issues.
rdale
Lansing, MI
True - but since he hasn't released ANY updates since the initial test version, it certainly offers a clue :)
lowboy654
DB Admin Member
Northwest, WA
I know this what I was asking for so that everyone dose not keep asking or stating that it will not work with Vista is for Rick to let us know in this Thread when it does.
rdale
Lansing, MI
It does work with Vista - just have some issues with the menu options and displays...
lowboy654
DB Admin Member
Northwest, WA
Every time I run it it, it will state uniform has stopped working
A problem caused the program to stop working correctly windows will close the program and notify if a solution is found, at this point you would be the only one that I know that it is working for.
rdale
Lansing, MI
Don't know what to tell you - I'm running Vista Business 64bit. You might just want to watch the download site and/or main thread and see when he releases an update.
Stick0413
Hopewell, VA
I think the key here is that you are running Vista 64 bit. I have Vista Home Premium on both my desktop and laptop and had no luck. XP on the other hand works.
DaveIN
Founders Curmudgen
West Michigan
Same here. It seems to die when trying to select the com port. The menus are a work in progress, from what I can tell.
Stick0413
Hopewell, VA
When I try to add a reciever and I click to change the type it stops working. Or if I click on other menu options it does the same.
kd5dga
Killeen,Texas
Same problem here on a new VISTA machine. However untill there is a new release that will allow the new beta version work, I'll stay with the older version.Same function without the nice user interface.
I give UNITRUNKER allot of credit for his work.
