Unitrunker Unitrunker band plan TX offset
MTL_Emergencies
Member++
Quebec, Canada
I decoded this info with Unitrunker for my local P25 trunked system (Motorola P25 Phase II).
What would be the TX offset for the channel 799.00625/806/812/818 and would the channels located on slot 2 be TDMA?
GTR8000
NY/NJ Database Guy
BEE00
The latest version of Unitrunker 2.1.0.104 includes the TX offset. You have to right-click on the column headers to unhide them.
And yes, the "2 Slot" band plan elements are TDMA. It's not showing "Slot 2" but rather "2 Slots" aka TDMA.
(edited because I'm an idiot)
GTR8000
NY/NJ Database Guy
BEE00
I see that you're in Canada, so this may not apply up there, but the standard offset for 700 MHz is +30 MHz and for 800 MHz -45 MHz here in the States.
What do you need the TX offsets for? If you need to transmit, then you should have an authorized radio that is already programmed.
Thanks @GTR8000 I was unaware it showed offsets, not that I have ever needed them.
GTR8000
NY/NJ Database Guy
BEE00
Recently added feature in either 2.1.0.103 or 104, don't recall exactly which release. Hidden by default.
And I'm guessing standards for 900 is -39?
MTL_Emergencies
Member++
Quebec, Canada
Thanks! The Unitrunker 2.1.0.104 did the job. I wanted to add a P25 channel ID on the system page (I see other systems do have a P25 channel ID table).
GTR8000
NY/NJ Database Guy
BEE00
That's 100% on me, I a) didn't read your post clearly enough b) somehow didn't even notice your dbadmin badge (not red enough I guess) and c) jumped to the conclusion that you were trying to program a radio. My apologies, I'm an idiot.
merlin
DN32su
How might someone program a Harris unity with the channel IDs ?
