BANDIT said:
Thanks for checking in - trying to get the next beta release out the door.
Here's a list of things that *should* be fixed in the next release.
Fixed for next release (0.1.0.19)
1. Self-describing data files (first line of text lists the column names).
2. shift-tab works as expected (moves cursor to previous field instead of next field).
3. priority was missing from GID and RID files.
4. It keeps changing all my priorities back to 50. It will not save them. Changes them back even if I edit the file (BANDIT 24-May-2005).
Save menu option added to manually save. Fixed for talkgroups and radio ids.
5. "Hit <Return> to Save if the cursor is in the Listen or Lockout fields on the Subscriber or Talkgroup edit (Find) screens." loumaag 28-May-2005
6. "I discovered that if you put commas in the alpha text tags of the talkgroup ID's, the program won't display any text to the right of the first comma." W4KKR 26-May-2005 Tolerates commas for text label and text notes fields (requires enclosing double-quotes which the program automatically provides). Probably has problems with embedded double quotes.
7. "Is there a reason that 1073741824 (1024^3) is added to the affiliated talkgroup ID in the file as it is saved?" Jay 26-May-2005 The bookkeeping bits are removed when the data is saved.
8. "I noticed that the public beta still misreport the radio ID which the radio setup a I-call. for example, the radio 091A call to 0312, Unitrunker display the 091A as 0910, always a 0 fill the last number.... even I changed the display mode to DEC, it still misreport the ID." Wang-He 26-May-2005 (Fixed: thanks for the feedback!)
9. MPT1327 support - now features a real FFSK decoder - other minor improvements. Note: you can use speaker audio for this type of signal.
10. Does not seem to have enough "memory" ... (25-May-2005 wwhitby). The raised cosine filter that was supposed to improve P25 signal decoding - has been removed - considerable reduction in CPU consumption.
More to come ...
-rick
